Old 06-09-2002, 10:32 AM
trudellt's Avatar
trudellt trudellt is offline
Cobra Make, Engine: Superformance - 514CID
Thanks for the help guys!
I removed the starter a few minutes ago and found 2 things wrong - I think.
First, the solonoid assembly was loose. One screw was 1 turn from being tight and the other had just about fallen out. I could rock the assy. about 1/8" back and forth.
The second problem I believe is the bearings. When I turn the pinion drive gear, it is really rough with uneven resistance as I go around.
The ring gear looks fine, but the drive gear is showing slight wear. There was about a cc worth of metal scrapings captured in the grease in the housing.
I'm going to purchase a PA Performance or Ford mini starter and post how it goes.
"There's nothing in my garage worth
your life."
