Old 10-14-2019, 04:06 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Jim Coleman View Post
OK, in checking the balancer, I see there are 4 separate lines with numbered marks. I need to know which line to use as there are
four choices. Got a feeling that I was using the wrong one.
5/8
6/1
2/3
7/4
Is Top Dead Center 6/1 ? That seems to center with the keyway.
Thanks,
Jim
A degreed balancer for a small block in firing order, the first lap is 1872, the second lap is 6543, to give 18726543.
1 and 6 are at TDC at the same time, when 1 is at compression TDC, 6 is at valve overlap,(end of exhaust, beginning of intake).
Same for the pairings, 8 and 5, 7 and 4, and 2 and 3.
I hope you are reading all of this Jim, since many boys have attempted to help you here.
I have seen how to find TDC compression a few times in this thread.
Gary
