Old 10-15-2019, 11:31 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Jim Coleman View Post
Patrickt:
It appears that the balancer is at 2 degrees after tdc (The line marked 5-8 on the balancer if the stick is all the way up), and the rotor is pointing at cylinder#3 instead of #1.
Do I need to start over?
Thanks,
Jim
Jim,
The 5-8 mark would be 90 degrees after the 1-6 mark.
The 1-6 mark is the one that should line up when finding TDC on cylinder 1, (or 6).
So the balancer outer ring has shifted, or some other abnormality.
And if you are on TDC 1, then the rotor pointing at 3, is why it won't start.
I am more concerned at why the balancer does not line up.
Gary
