Old 10-19-2019, 07:47 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by cobrabritt83 View Post
Thanks for the help, I will post some pictures soon. As far as the issue, the pressure plate without the clutch disc mounts flat on the flywheel. I think the issue I'm having is the clutch disc wont press into the pressure plate when torqueing down the bolts. I bought everything brand new as a kit that included the clutch disc, pressure plate, and bearing.
So with only the pressure plate on the flywheel, what is the gap between the pressure plate and the flywheel?
You can see and measure this in 3 positions around the outer of the clutch cover.
Gary
