10-20-2019, 04:19 AM
AR
If the pressure plate sits flat against the flywheel (without disc installed) with no gap you definitely have a Centerforce clutch with something wrong with it. Cross torquing down the PP bolts evenly with the disc installed should easily compress the PP disc as the PP bonnet is pulled up against the flywheel. If not you need to return it.
