Old 10-27-2019, 11:04 AM
andronikos916 andronikos916 is offline
Default Engine Oil Pressure Tester - 351w>408
Hello everyone,
Can someone point out a good Engine Oil Pressure Tester to purchase for my Backdraft Cobra (351w>stroked to>408).
All is running very good with the car but I am curious how accurate the gauge actually is on my car and if I should trust it.
Also, I am using a lighter 5w30 Amsoil Signature Series oil instead of a
heavy 20w50 after a research on the oil / psi topic. Which in summary I should get 10psi when hot for every 1000rpm from the oil pump.
Another topic where you can read more here about oils: (do a search for Amsoil)
https://540ratblog.wordpress.com/201...-test-ranking/
Thank you,
Andronikos
