Old 11-09-2019, 07:40 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by FredG View Post
Hi Bob. Two questions. Where did you measure to get these numbers?
Ride height today:
Front- 7.00"...……. 7.375"
Rear-- 8.25"...…… 8.25"
and after you adjusted the front, did you still have play in the spring with the suspension hanging?
Thanks
Fred
I used the outriggers. In the front just before the weld, and in the rear at the jack point. It sits a little bit higher than most cars I've seen, maybe about an inch. But around here, that seems to keep the nose out of the concrete.
Originally Posted by Seagull81 View Post
Don't forget to recheck your front end alignment after raising or lowering your car. Toe out will make your car spooky on the street.
This is true. Front and rear should have a smidgen of toe in.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
