  #37 (permalink)
Old 11-09-2019, 05:40 PM
razerwire razerwire is offline
Cobra Make, Engine: csx4163 full comp alu. body
Every ones garage gets messy when you are doing projects. You need to inspect your lift regularly, pins loose or fell out, you let to much slack when you lower lift on stops and cable slips off pully, then when you raise next time cable is between frame and not on pully cutting cable. Cheaper the lift the more sloppy the pulleys and smaller diameter they are. Bigger pulleys and ones with greaseable bearings are better.
