Old 11-15-2019, 04:38 AM
David Hodgson's Avatar
David Hodgson David Hodgson is offline
Hi gcarm, it sounds like you've had several goes at resetting this. What adjustment do you make each time to put back right again?
Have you replaced the rubbers at the front of the radius rods?
The lower control arm will shift back and forth if these are worn affecting toe, but shouldn't affect camber much
SLIPRY
