Thread: melonized gear
  #29 (permalink)
Old 11-15-2019, 02:43 PM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
If anyone is interested, my mill performs best at 35 degrees all in. To get there, I use the silver bushing and spring combo to achieve the following curve, which is just right for me. This is an MSD distributor with no vacuum advance. One advantage of an initial setting of ten degrees is that it makes cranking a bit easier, which helps the starter motor, flywheel teeth, and what not.
When was the last time you checked your timing. Car running rev to 3000 rpm then watch it go back to set point?
