Old 11-18-2019, 05:59 PM
patrickt patrickt is offline
And don't forget to have your zerk fitting in compression on the u-joints on the drive shaft. Of course, if you have a Jag rear with inboard brakes then those u-joints on the half shafts will always be in compression or tension depending on whether you're braking or accelerating, so it doesn't really matter. That's a bar room bet that you'll win more often than not.
