Thread: Oil Change
Old 11-19-2019, 06:51 AM
sea2jet sea2jet is offline
Cobra Make, Engine: ERA 744/428/TKO 600
10 psi at idle seems very low.
Originally Posted by cycleguy55 View Post
The weight / viscosity of your oil s/b based upon the clearances in the engine, as indicated by pressures you're seeing. Standard guidance for many has been 10 PSI per 1,000 RPM at operating temperature, so 60 PSI @ 6,000 RPM. Running heavier / thicker oil than that not only requires more power to pump, but may also result in insufficient lubrication to tight clearances - particularly when cold (yes, even with multi-viscosity oils).
