Old 11-22-2019, 06:51 PM
Cobra #3170 Cobra #3170 is offline
Default No ABS
Originally Posted by t walgamuth View Post
What happens to your times if you turn it off?
We lose about .5 seconds every 30 seconds based on what the data acquisition says with no ABS. I was going through the engine data on Fridays test runs and found a correlation between system voltage and high rpm. Seems that every time we got an ABS Mil light there was a voltage spike going as high as 16.2 volts so I was wrong about a solid supply voltage. It may be that the engine accelerates at a greater rate than the regulator can control the alternator flux field. I am thinking of putting a couple of high current silicone diodes in series to lower the ABS supply voltage. That may solve this issue. I have not heard back from Bosch yet either. The ABS system has tremendous potential and we have not scratched the surface yet (still using the first setting).
