11-24-2019, 10:17 AM
CA
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
no need to pull the motor, if you have a lift no problem. Pull the seats, the tunnel, drive shaft and back out the tranny (you will need to support the rear of the motor a floor jack under the car works). Then remove bellhousing, then you can access the clutch and flywheel no problem.
