Thread: Gear oil????
Old 11-28-2019, 03:23 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
351, 9psi, and pinion oil seal leak.
My bet is the pinion bearings are wearing, insufficient bearing preload, pinion moves under load, pinion oil seal weeps.
You should also check your diff breather system is clear.
Don't ever do a pinion seal unless you know what you are doing.
Gary
