Thread: Oil Change
  #34 (permalink)
Old 12-03-2019, 07:55 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by RB60 View Post
Maybe a stupid question, but my engine builder recommends 20-50 Valvoline, which I run in my 427 FE. My garage is not heated and the temps are in the 35 to 40 degree range here in PA. Will I run the risk of snapping the oil pump shaft or spinning a bearing if I try to start my engine in these temps? The reason I want to start it is a friend who owns a car dealership wants to put it in his showroom which is heated and I would like it in the controlled environment and have the extra space in my garage.
Not a real problem. When cold, it's a 20w. It won't be thick enough to snap a drive shaft. It will take a while to build pressure and lube everything. Give it a few minutes in the garage to get the temps up before driving it.
If you have an oil cooler, cover it up.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
