Old 12-16-2019, 11:05 AM
olddog olddog is offline
Often times when oil is running down the valve stems (guides or seals), it will continue to run down for some time after the engine is shut off. Then when restarted, a nice puff of blue belches out the pipes. Also when you pull the intake, you should see oil on top of the valves.
Compression rings (top two) and oil rings (the bottom groove) work totally differently. It is possible to have good compression and the oil rings not work worth a hoot.
