Old 12-16-2019, 12:01 PM
cycleguy55's Avatar
Originally Posted by tortuga View Post
Ford racing 427/535
Been eating oil since day 1.
Not a pcv problem, have Walker pcv with catch tank
Replaced intake gaskets half a dozen times
Compression is 215+/- single digit all 8
Replaced all valve guide seals
Plugs look good albeit a little dark
Has to be valve guides?
Question: what’s the best nor cal machine shop to have the heads gone through?
Steve H
SPF 1764
Had similar oil consumption problems with mild 460. I replaced my valve stem seals as well, but that had little effect.
Turns out the root cause was the intake manifold gaskets weren't properly sealed, allowing oil to be sucked from the valley into intake ports. Drain coolant, pull the intake manifold and carefully inspect the gaskets for signs of leakage.
Brian
