Old 12-17-2019, 05:26 AM
tortuga tortuga is offline
Default Interesting
You simply can't put any of these engines together reliably without using sealant on both sides of the intake gaskets. Every engine I build, whether it's a Windsor, Cleveland, FE, etc., gets the gaskets glued to the heads, and sealant between the gasket and the intake.
All the gasket makers say to go commando...but I’m getting so quick at swapping out the manifold these days I may have another go...interestingly enough I read a review on summit where a guy does the same: glues (permatex aviation sealant) the gasket to the head, sets it by snugging down the intake, waits, then checks and then glues the intake to the gasket.
Another thing, whatever is going on seems equal in all holes as the plugs all look the same...
Steve H
Superformance 1764
Built 427W
Aiken SC USA
