Old 12-18-2019, 10:25 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
When you reinstall the side pipes, be sure to use a little teflon thread sealant so you're less likely to have the same problem next time. Also, the header bolt shown in your picture uses a 7/16" wrench. Switch to bolts that have a 3/8" head (ARP makes them). That will allow you to use a box end wrench rather than an open end wrench.
