  #22 (permalink)
Old 12-29-2019, 01:20 PM
tortuga tortuga is offline
Default Second manifold already...
Yeah, I don’t care what the gasket makers say. Use sealant or you’ll be doing it again.
Glue the gaskets to the heads, set the intake on overnight to mash the gaskets down, then come back with another layer of sealant, lay beads for china walls, then bolt it down.
Tightening the intake down isn’t causing your problems.
I’m also going to grind off the raised portion of the manifold Where it meets the China walls (raised when upside down). It does rock a very little when set on the engine without gaskets, ford instructions say there should be .040” at China walls with manifold on engine sans gaskets...
P.S. man this permatex aviation gasket maker is some really messy $hit...
Superformance 1764
Built 427W
Aiken SC USA
