Old 01-06-2020, 06:46 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
you should be fine. Maybe an issue if you drag w sticky tires
i think the 3550 is somewhat based off of the toploader. ford initially designed the small spline toploader, which they were putting behind galaxies and 427's. i think they were having issues at the drags, and redesigned the toploader with a thicker input and output shafts to solve the problem. since the cobra is a lot lighter, there will be less stress on holeshots.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
