Old 01-10-2020, 08:34 PM
ERA 626's Avatar
ERA 626 ERA 626 is offline
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Default electronic smith oil pressure gauge
Here is the issue:
I have a brand new electronic Smith oil pressure gauge I got from nissonger.
I wired it up exactly per instructions, This is a new motor build so there is no oil in the block it is just a mock up at this point.
When I turn on the key the gauge goes to 95 PSI and stays there. I tripple checked the wiring ( hot, ground, sender input) it is all good.
I called nissonger and he told me that it could be a grounding issue to the sender, this makes no sense to me because the gauge has a ground wire running to the sender, so I also grounded the sender to the chassis ground, same issue. Same result if I disconnect the sender, so to me this rules out the sender.
I had him send me a new gauge, same thing. So I turned on the key and applied an air compressor to the gauge to see if I get a reading, when I do this the gauge goes to 100psi then back to 95 PSI... Is this normal? I need advise on this.
