  #28 (permalink)
Old 01-15-2020, 09:14 AM
olddog olddog is offline
Double check that polymer gear on the distributor. You might want to ask some questions on that.
Also, spring for the best heads you can afford. Maybe port work on those heads, or maybe a better set of heads. The difference in cost may be fairly minor. It's worth a conversation, if you could afford a few hundred more.
