Old 06-10-2002, 08:00 PM
marlowe marlowe is offline
Default Which wires
Gary, Thanks for the fast response. Looking at my wiring diagram from SPF, its almost impossible to figure the wiring colors and routing! Wires start one color, go thru plugs and end up different colors. They don't produce a wiring diagram that I am used to seeing.
If I wire the MSD direct as you indicated, must I remove any of the SPF wiring? Does the ballast resistor need to be taken out? Do I need to put in the diode MSD suggests so it won't run on after shutoff? Thanks.
