Old 01-21-2020, 06:59 PM
FredG's Avatar
FredG FredG is offline
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Update and components.
I will be wrapping this up by the weekend as the mounting brackets arrive tomorrow and I am sure they will require a little tweeking. The fans are mostly cosmetic because my Roush 427r never runs hot and the puller effectively keeps it cool. The fans will work separate from the puller and be controlled with a toggle. I took the 12v power source directly from the back of power shut off ran it through a 30 amp Auto reset breaker. From there it goes to a normally off relay that will be turned on when the key is on. Power from the relay goes to the SPST toggle that has a mini LED connected in parallel to act as an on indicator. In other words. Start the car. Throw the toggle. the fans and light come on. Simple as that. Here are pictures of the parts. Every connection is either soldered or crimped and sealed with shrink wrap. Here are the pics of the parts. If anyone needs links, I will provide them to you.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
