Old 01-23-2020, 09:06 AM
bobcowan's Avatar
bobcowan bobcowan is offline
If you're using stock components, you can find a stock balancer that has a built in trigger wheel. Swap to a front cover to match, and then just add the sensor of your choice. Makes it real easy.
If you're racing, though, you probably don't want to use a stock balancer.
I couldn't find exactly what I wanted in the aftermarket. I ended up making everything I needed. I connected it to a Megasquirt ECU and ran a coil pack, eliminating the distributer from the ignition system.
Very accurate, and dead nuts reliable. Raced/drove it for four years without a hitch.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
