Old 01-30-2020, 10:40 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
The 58mm webers were mounted straight up. They have a different, wider bolt paqttern than 48IDA's. Holman moody made the intakes, and most of them were for Hi-Riser heads, lthough I have seen a couple for medium risers. Hilborn adapted a mechanical fuel injection system for the intakes.
Weber carbs put out a graph guiding the size of carb you need based upon the cylinder size and RPM's
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
