  #21 (permalink)
Old 02-25-2020, 08:15 PM
soroush soroush is offline
on the last pic you can see the absence of the originally equipped slave cylinder and clutch fork, I removed all that stuff in lieu of a hydraulic throw out bearing from tilton when I replaced the clutch to a new dual disk set up from mcloud. so that area is cleaned up a bit also.. allows the fuel lines to sit on the rails a little nicer..
