Old 02-29-2020, 09:42 PM
snakeeyes's Avatar
snakeeyes snakeeyes is offline
Originally Posted by tomshep View Post
Great info and helps fill in the gaps some.
I see Hi-Tech being mentioned here and other responses. Did they exist before SPF? I though SPF was started in South Africa. Which came first?
Tom
It’s easy to get confused because there are actually two Hi-Techs in Cobra lore. The first was begun by Tom D’Antonio in, I believe, Arizona in the 90s. Tom is actually a Club Cobra member who goes by “Tjd” so maybe he’ll stop in here. THAT Hi-Tech didn’t stick around too long but while they existed they built some of the most accurate replicas out there. They were the first replica to build a frame so accurate that original Cobra parts were interchangeable, and they offered aluminum body options before that became common.
The second Hi-Tech is the South African one. My knowledge about where they fit into things is limited so I’ll let others take up that thread if they want, but I don’t believe there is any connection between the two companies beyond the name.
