Old 03-04-2020, 01:00 PM
olddog olddog is offline
Do all four holes have a restrictor press in? If yes, then it was likely done to restrict oil flow.
If not, then it is possible that the tube that is pressed in was a piss poor attempt to fix a known crack in the block. Perhaps it didn't seal or perhaps the crack migrated further past the tube. Getting to too many ifs, but if so you would need to pull the tube to see what's going on.
