Old 03-04-2020, 03:24 PM
1795's Avatar
1795 1795 is offline
Originally Posted by Morris View Post
PS. You should never lock up your brakes at anytime on a racetrack...Any time you loose adhesion between the track and the tires is bad and Bad things will happen...
So make sure your brakes are bedded in correctly and "Smooth is Fast"
Morris,
Thanks for your input. Was hoping that you would find your way to this thread, and yes, I agree with you 100% that you do not want to lockup your brakes on the track. Only bad things can come of it. If something is so bad ahead that you think that you need to lock the brakes to avoid a collision, it's time for a controlled spin.
Jim
