Old 03-07-2020, 12:58 AM
xb-60's Avatar
xb-60 xb-60 is offline
Next was to fit the radiator assembly to the car. The supplied side panels/brackets positioned the rad. assembly way too low. Had to drill new 18mm dia. holes in the brackets and also remove metal from the top as well as the bottom of the brackets. No sweat, except it all takes time. Make a mistake, and I'm in trouble.
Worked out OK, so here's the rad. assembly fitted to the car....
