Old 03-18-2020, 07:49 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Cobra #3170 View Post
I was going through the engine data on Fridays test runs and found a correlation between system voltage and high rpm. Seems that every time we got an ABS Mil light there was a voltage spike going as high as 16.2 volts so I was wrong about a solid supply voltage. It may be that the engine accelerates at a greater rate than the regulator can control the alternator flux field. I am thinking of putting a couple of high current silicone diodes in series to lower the ABS supply voltage. That may solve this issue.
Other options may be installing an oversize pulley on the alternator and/or undersize pulley on crank, to slow down alternator's rpm's, and also installing a manual/remote disconnect switch from the alternator field wire, or bat terminal, and running solely off the battery during high rpm runs.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
