Thread: oil temp
Old 03-23-2020, 12:13 PM
ACHiPo's Avatar
ACHiPo ACHiPo is offline
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
I saw your post over on the FordFE forum. When you pull your sensor out and stick it in a pot of boiling water, if the needle on the gauge goes right up to 100 degrees Celsius, then it pretty much has to be a goofy result of the placement of the sensor in the pan. We've seen that happen from time to time on oil temp sensors. But you've pretty much got to do that test -- you can't just live with a gauge that gives you the wrong readings.
See no evil?
