Old 03-28-2020, 08:56 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
I think as long as your voltage is within normal limits, it's fine.
The ammeter measures the direction and flow rate of electricity. After starting your car, the battery is being recharged after being drained, and as the car runs, the battery recharges, the value should decrease. If you normally have a battery charger on your car, then your battery should recover more quickly, if not, it will take longer to recharge, and the ammeter will still be at a higher level for a longer period of time.
Also, the value of the ammeter may be affected by how the ammeter is connected to the electrical system of the car.
Again, as long as your voltage is OK, then I think you are fine.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
