Old 03-28-2020, 11:33 AM
patrickt patrickt is offline
Remember, your ammeter is measuring current. If your battery is fully charged, and you fire her up, it's perfectly normal to see 25 amps going through the meter for a couple of minutes as the battery recharges to full capacity. If you are still seeing greater than a few amps going through the meter after the car has been running a while, and your system voltage is a normal value of under 14ish volts, then you have to ask "where is the load on that side of the gauge?" Is there a high amp load (like a fancy audio system), or maybe an ignition system, maybe the fans, that are wired directly to the positive terminal of the battery? Or to a lug that is between the ammeter and the battery? Or maybe it's a poor connection that is creating heat -- just like a space heater. Or maybe it's the battery itself. Remember, you only have amps measuring on your gauge when you have current, and you only have current when you have a load of some sort. 99.9% of the time, there is less than a couple of amps running through your ammeter, and that's just to keep the battery trickle charging after it has been fully charged up.
