Old 04-01-2020, 04:34 PM
EM-0785's Avatar
EM-0785 EM-0785 is offline
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Battery Tender brand, really do like it. Can find model later if interested.
For access, if helpful...
Initially with battery & cutoff switch front and center behind bulkhead, attached with nuts, dropped capped lead through access hole in vinyl trunk panel into trunk. When connected, cord ran under gently set trunk lid with soft cloth.
Currently moved battery & cut-off to rear pass side of trunk. Created an access hole out beneath at rear and dropped/fastened the capped lead tight below trunk for anytime access without opening the trunk.
Brent
