Old 04-03-2020, 12:19 PM
jolsen42's Avatar
jolsen42 jolsen42 is offline
Originally Posted by Ivygreen65 View Post
Now THAT'S motivation. Actually, I have been working on it. Bruce positioned the engine in the chassis similar to the FF5 roadster, which I believe is about 2" back. That 2" set back led to a lot of issues when I started mocking things up. Firewall issues, footbox sizing issues, shifter location, etc. But, the biggest thing was I just didn't think it looked right. So, I cut out the engine mount pillars, fabricated new pieces, and moved everything forward 2" It was quite a bit of work, but I think it was worth it and I'm happy with the results.
I don't know if you remember, but I moved mine up 3 inches much for the same reasons, but I also moved up the front cross brace 5" because of the engine being closer the pulleys and fan belt were too close and would have hit the cross member. How did I know that? I trial fit the motor after the new motor mounts.
Looking forward to your progress.
John O
jjo42
