Old 04-09-2020, 02:37 PM
1BIG67AC's Avatar
1BIG67AC 1BIG67AC is offline
Cobra Make, Engine: 1967 Antique and Collectibles Autos, Inc, 302
H-Rod
The A&C instructions say to measure 22.5 inch back from the top front cross member and mark the frame at this point. This is where the middle of the two center header pipes line up on the frame. Then mark the holes on the frame using the frame mounts attached to the motor. This is what I’m worried about. If these header are ok to use this measurement. I want this motor mounted in the chassis. Should I go ahead and drill and mount motor mounts or not with these headers? If you look hard it the picture I attached shows that mark on the frame. Should I go ahead and drill and mount? Thoughts?
