Old 04-10-2020, 05:48 AM
blykins blykins is offline
I'm not a T-56 fan and never really have been. They are longer than a TKO, bigger around, and heavier. I have also never really seen a situation where you need two overdrives.
For a SBF making 425-450 hp, the torque will be down around 375-400 lb-ft. You have lots of options there: a TKO 600, a worked T5, or a Toploader.
The T5 and the Toploader are the best shifting transmissions out there, bar none. The TKOs are a little notchy, but better when they break in, and are even better when they are modified internally.
For a peakier engine, (read shifting over 6000 rpm), I would recommend the internally modified TKO 600 if you go that route.
Depending on the rear gear ratio and where you plan on driving the car the most, a Toploader makes a VERY nice drivetrain complement, and if you go with the factory 289 block/factory heads, the drivetrain would all look period correct.
I have seen more and more guys opting for completely period correct builds, especially in the nice cars like the ERAs, Kirkhams, etc.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
