Old 04-10-2020, 08:04 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by PCW View Post
Working with Peter to finalize my build cost and I have most of my build nailed down. Still deciding on the engine builder, but the car will be a FIA 289 with either a 331 or 363 ci with an 8 stack carb weber set up, targeting approx. 425-450 HP. The biggest question I still have is what trans to use.
I would think Peter would be able to give you the best advice. I think any of the transmissions will work, the main thing is to match the tranny with the appropriate rear gear.
The only advice I have, is that if you are going to go with a toploader, and you think at some point in the future you may change to an overdrive tranny, I'd make sure the frame/crossmember is done correctly now, if needed, to accommodate any future tranny swap.
If you are going to buy a new/ rebuilt toploader, I'd go with david kee.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
