Old 04-13-2020, 07:13 AM
1795's Avatar
1795 1795 is offline
Originally Posted by Argess View Post
Doesn't a flatbed have the winch in the center, so the pull won't be straight if that's the case. Gets worse the farther up the flatbed you are. Honestly, I never really noticed if a flatbed winch can be moved laterally.
And any side load would be doubled with only one strap....
Also, there will be a twisting torque on the whole car when you pull it from one side, so there will be side-loads even if it is a straight pull. If the whole business is beefy enough, everything will be OK.
But is it? Patrick's ERA looks different than my older one, if I remember correctly. I wouldn't trust the threaded rods in mine for this purpose as I think they would bend quite easily.
Mind you, Patrick is committed now as he's drilled the hole, so he might as well try it and see what happens.
Good point about the winch typical being in the center. When I installed the winch on my trailer it was offset to the side that the strap was attached to the quick jack, so it is more of a straight line pull.
