Old 04-15-2020, 05:04 PM
ERA 626's Avatar
ERA 626 ERA 626 is offline
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Default Smiths electronic speedo trouble shoot
I got a set of smith gauges from Nissonger. I have the electronic Speedometer with the electronic odometer. It has a momentary button to reset the miles (trip odometer) and the button also is supposed to get you into calibration mode. This is a new install. The directions say while turning on the key press and hold the button and the odometer will begin to flash meaning you are in calibration mode. Well the button does nothing. I put an ohm meter across the momentary button to test the button it self and it is working... I called the guy at nissonger and he said make sure it is wired to the transmission... I was thinking to my self it should not make any difference if it is wired to the transmission or not, but OK I said I would wire it up the the electronic sender on the Tremic TKO (one ground wire and one pulse wire) sure enough it still does not work... Does any one here have any experience with these electronic speedometers?
