  #23 (permalink)
Old 04-18-2020, 08:47 AM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Default cam
Hi,
Roller cams do not need a break in period. All other cams need to have special lube put on lobes to be run in at 2000 rpm for 20 minutes to seat the lifters to the cam lobes. The engine oil has to be rich in zinc otherwise the lifters and cam will be destroyed. You can use zinc additives in the ordinary oil and must use them all the time in your engine as modern oils took out these additives for emissions.
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
