Old 04-20-2020, 03:28 AM
blykins blykins is offline
The original FE's had rope seals and were not aluminum.
You can pretty much expect a leak from an aluminum FE block. It's just the nature of it.
I haven't had (knock on wood) a cast iron block rear main seal leak in forever. Seriously, I can't remember the last time.
I don't use the side seals and nails. I use silicone. Works perfectly, doesn't take forever to shape the nails, and you don't have to worry about the varying side seal cavity sizes on different blocks.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
