Old 04-24-2020, 08:25 AM
Larry A Davis Larry A Davis is offline
Cobra Make, Engine: SMC, 427 Shelby aluminum block
Default output shaft seal
My Tremec t56 Magnum trans is leaking fluid. It is apparently due to a bad output shaft seal. I was told that due to a severe pinion angle of the driveshaft, a new seal may not work for long. Does that sound correct? I know nothing about transmissions and cannot see anything under the car without a lift. No jack will fit under the car either. I am in a rural area with no shops locally. May just replace the seal and sell the car.
