Old 04-24-2020, 12:19 PM
67sn8ke's Avatar
67sn8ke 67sn8ke is offline
Cobra Make, Engine: Shell Valley, 408 Stroker
I would think severe pinion angle would wear U-Joint's out more then anything and shouldn't have anything to do with the output shaft seal leaking. Changing the seal shouldn't be a problem if you can get your car off of the ground to get to it. Just my 2 cents!!
