Old 04-25-2020, 08:07 AM
Larry A Davis Larry A Davis is offline
Cobra Make, Engine: SMC, 427 Shelby aluminum block
Default Trans problems
Thanks to all who responded. I need to check the driveshaft for excessive up and down movement which would indicate the bushing is bad as well. I don't know if this is normal wear for the most part or what. I have ordered the seal but can't really find the bushing if needed. Any idea's as to where that item can be found? I've discovered since the trans is probably aftermarket Tremec as opposed to an OEM it's a crap shoot. Not even sure the seal I ordered is correct.
