Old 05-02-2020, 01:40 PM
Ivygreen65's Avatar
Ivygreen65 Ivygreen65 is offline
Spent last night with a bottle of Meomi, my dash, and everything that goes into it. I need to weld on dash mounting brackets and want to make sure they’re located correctly. I also wanted to make sure behind dash clearance was as good as it can be - I don’t want to be cutting and welding anything later.
Using a couple of known gauge measurements, I was able to scale some straight-on photos I had and determine a pretty accurate (based on the eye test) placement. Bruce’s dash had some landmarks molded in that proved to be very accurate, so this wasn’t a very difficult process. After a quick inventory, I think I have everything for the dash except the glove box latch. I’ll box everything back up until it’s time to install the dash.
